Re: Wireless mDNS Bridging CLI command
Was there ever a real response / solution to the original question ?
Because I think I might have the same problem.
9800 -> Configuration -> Services -> Multicast - Wireless mDNS Bridging (enable or disable)
What is the equivalent CLI command ?
Our scenario is that it seems that Catalyst Center disables this single feature, on provision, and we would "just" create a CLI template that enables it. But we simply cannot find the added command in the configuration. Also in a "diff" of startup / running.
Documentation does not seem to cover this, only that you can see it enabled through show commands, but not "the" command to enable it.
Cheers - Thomas
Mark Elsen
  - @Thomas Obbekaer Thomsen               You must have Global Wireless Multicast Mode set to Enabled if
        you want to enable Wireless mDNS Bridging
                                If you are looking for the related CLI commands ; checkout and install
                                https://goodwi.fi/posts/2025/01/find-9800-cli-cmd/      ( clicatcher )
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
aleabrahao
Meraki Community All-Star
To Enable:
wireless multicast link-local
To Disable:
no wireless multicast link-local
Beginning with Cisco IOS-XE 17.6.1 and later, when you enable global wireless multicast (wireless multicast), link-local multicast bridging (which handles mDNS) is enabled by default.
To override what Catalyst Center is pushing and force-enable the feature, you can add the following block to your CLI template:
wireless multicast
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Rich R
@Thomas Obbekaer Thomsen fyi also see https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-18/config-guide/b_wl_17_18_cg/m_link_local_bridging.html
Lots of confusion around this feature and the change in behaviour after 17.6 - see https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd59093 - 47 customer TAC cases attached!
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
