Realtime Signal Strength Monitoring
davidstedman
I am attempting to use several thrid party programs to display realtime graphical representation of signal strength and quality of several dozen BR350's. My problem is that each of the OID's I have attempted to use generate errors like "No such name". I am curretnly trying to use PRTG Traffic grapher SNMP if you are interested. Any help would be appreciated.
ebreniz
Level 6
Level 6
abwahid
Level 4
Level 4
The "No such name" error means that the specified SNMP object was not found. This can have various reasons - changed OID, network connection problems, etc.
As a first step, please use any SNMP Tester to check if you can properly connect to your device
gohussai
Level 4
Level 4
Check the following link for SNMP with MRTG for Real time signals Analysis.
https://wiki.ubnt.com/SNMP_and_MRTG_Monitoring
Also check the following Cisco portal for OID finding..
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.661
