Reauthentication Issue
Prasan Venky
Level 7
Level 7
We have our controller 5508 running with 7.5 firmware. But now we face user just getting disconnected and asking for reauthentication regardless of any timer settings. It creates lot of issues. When at 7.4 there was no issue.
My Session timer is 36000 and idle timer is 18000
But still every 20-30 minutes we have to reauthenticate. Strange !!
Any help ...
9 Replies 9
Sandeep Choudhary
can you paste the logs.....
debug client
         Here is the debug logs .(IP's changed for security)
We have foreign- anchor setup.
You have the session timer and the idle timer set on the anchor or foreign or both? For WebAuth, it should be on the anchor.
-Scott
Yeah.. We have set the same settings both the side.
Scott Fella
Prasan,
Can you post your show WLAN is the issues with all clients of have you been able to isolate it to a specific device, certain AP or site, or radio band?
-Scott
Hi Scott,
Many of the mobile client are facing this issue.
certain AP or site - Site
Radio band - 802.11 an
I will attach show WLAN shortly ...
So the 2.4 ghz is fine? Only the 5ghz is the issue?
-Scott
Both ...Wrongly mentioned as an
Post the show wlan for both WLC's.  Just want to verify the settings.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
