Recommended Code level
robertperry
Community Member
do you recommed 4.0.206
Also for guest wireless,putting a 2000 controller in the DMZ, can it handle the connections.
yong1794
Level 3
Level 3
I have upgraded 4.0.206 code recently. I think this code is more stable than formmer code as 4.0.179.11.
You cannot depoly 2006 controller in DMZ.
The anchor mobility for quest wireless is only supported by WLC 4400 seies or WISM.
Thank you very much
robertperry
Community Member
Greetings,
What is the difference b/w
s72033-ipservicesk9_wan.mz.122-18.SXF7.bin
and
s72033-ipservicesk9-mz.122-18.SXF7.bin
