Register remote AP to Controller through a VPN site to site
Alejandro.Angon
Does it possible register a Lightweight AP to remote Controller that are comunicated through a VPN site to site?
best regards
As a side note, you should upgrade your controller to a supported firmware version. Go for 7.4.121.0 for AireOS version & upgrade your FUS to 1.9.0.0 as well. The version you are running is having multiple critical bugs.
Product Version.................................. 7.4.100.60
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Here are the release note for these versions. FUS upgrade will take around 30-40min, so get sufficient outage window for the upgrade (at least 1 hour for both)
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn74mr02.html
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.pdf
Rasika
*** Pls rate all useful responses ***
15 Replies 15
Ali Aqrabawi
yes it is :)
Sandeep Choudhary
Yes it is possible.
Normally this technology is called flexconnect(old name was H-REAP).
Here are the modes:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81680-hreap-modes.html
HREAP Design:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/71250-h-reap-design-deploy.html
Dont forget to rate helpful posts
ok, I before configured H-REAP an FlexConnect, but through a Point to Point Link, and the AP refistered normally, now I´m triying to do it through a VPN site to site and the console AP only sends this messenge repeatly
%CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Ping responses from AP to WLC and from WLC to AP, do you have any idea of why the AP doesn´t register?
thanks
Check:
is AP got the IP via DHCP or statically ?
is there a Way for AP to find WLC ?
reboot the AP and post the entite bootup process here als paste the output of these commands:
sh sysinfo from WLC
sh version from AP
I configured the IP statically using the commands
capwap ap controller ip address
capwap ap ip address
capwap ap ip default-gateway
Here is the outputs
AP7c69.f640.de6e#
reload
Proceed with reload? [confirm]
Writing out the event log to flash:/event.log ...
*Jul 20 05:20:34.079: %SYS-5-RELOAD: Reload requested by cisco on console. Reload Reason: Reload Command.
*Jul 20 05:20:34.095: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 52 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 13725696
flashfs[0]: Bytes available: 18272256
flashfs[0]: flashfs fsck took 27 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 7c:69:f6:40:de:6e
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-mx.152-4.JB4"...##########################
File "flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-mx.152-4.JB4" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Tide MB - 32MB of flash
flashfs[0]: flashfs fsck took 18 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-xx.152-4.JB4;flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-mx.152-4.JB4'
Loading "flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-xx.152-4.JB4"...######################################
File "flash:/ap3g2-k9w8-mx.152-4.JB4/ap3g2-k9w8-xx.152-4.JB4" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(4)JB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 06-Mar-14 10:41 by prod_rel_team
Initializing flashfs...
flashfs[3]: 52 files, 8 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31739904
flashfs[3]: Bytes used: 13725696
flashfs[3]: Bytes available: 18014208
flashfs[3]: flashfs fsck took 11 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0  present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/B2.bin
Radio1  present 8764 8000 0 88000000 88010000 4
POWER TABLE FILENAME = ram:/B5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/ap3g2-rcvk9w8-mx/info (No such file or directory)cisco AIR-CAP2602E-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FTX1732J076
PowerPC CPU at 800MHz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.100.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:69:F6:40:DE:6E
Part Number                          : 73-14511-02
PCA Assembly Number                  : 800-37898-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17292QAP
Top Assembly Part Number             : 800-38357-01
Top Assembly Serial Number           : FTX1732J076
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP2602E-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:15.579: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)
*Mar  1 00:00:16.035: Registering HW DTLS
APAVC: Initial WLAN Buffers Given to System is  2500
APAVC:  WlanPAKs 18174 RadioPaks  17566
*Mar  1 00:00:18.415: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:22.223: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:28.551: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:28.755: Wait until the stile protocol list is initialized.
*Mar  1 00:00:31.767: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:33.955: Start STILE Activation
*Jul 20 05:20:33.043: %SYS-5-RESTART: System restarted --
*Jul 20 05:20:33.043: %SNMP-5-COLDSTART: SNMP agent on host AP7c69.f640.de6e is undergoing a cold start
*Jul 20 05:20:34.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to upERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Jul 20 05:20:48.399: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-8)
*Jul 20 05:20:48.399: DPAA Initialization Complete
*Jul 20 05:20:48.399: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Jul 20 05:20:49.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Jul 20 05:20:55.163: APAVC: Succeeded to activate all the STILE protocols.
*Jul 20 05:20:55.163: APAVC: Registering with CFT
APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching  Original Buffer pool for system use
Pool-ReAtach: paks 18174 radio17566
*Jul 20 05:21:06.515: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Jul 20 05:21:06.515: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jul 20 05:21:06.539: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Jul 20 05:21:06.743: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Jul 20 05:21:06.743: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 20 05:21:06.767: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul 20 05:21:06.767: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jul 20 05:21:07.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jul 20 05:21:07.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jul 20 05:21:16.755: Logging LWAPP message to 255.255.255.255.
*Jul 20 05:21:35.759: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Jul 20 05:21:48.039: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Jul 20 05:21:49.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 20 05:21:50.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jul 20 05:21:50.235: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 20 05:21:51.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jul 20 05:21:54.759: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
AP7c69.f640.de6e#sh version
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SOFTWARE (fc1)
AP7c69.f640.de6e uptime is 15 minutes
System image file is "flash:/ap3g2-k9w8-mx.152-4.J
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)B4/ap3g2-k9w8-xx.152-4.JB4"
Last reload reason:
export@cisco.com.
2 802.11 Radios
Configuration register is 0xF
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.10.30.187
Last Reset....................................... Power on reset
System Up Time................................... 36 days 18 hrs 10 mins 27 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... MX  - Mexico
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +28 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 4
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 50:57:A8:C7:0A:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 12
I realized that the reglatory domain configured on WLC and local APs is Mexico-N and the AP I testing is US-A, I didn´t have to enable multiple regulatory domains using newer WLC software releases, but I´ll enable to be sure
thanks.
Yes, It will not join to this WLC because AP is in different regulatery domain.
WLC is in mexco but AP is in -A- America Domain.It must be in -N- domain.
You can try to enable two country (Mexico and USA)on wlc then check it out.
Currently I can´t enable American domain, because I need shutdown the radios, but I got an American regulatory domain AP and happend the same behavior
best regards
You need a mexican domain AP to connect to this WLC (country configured as mexico).
regards
Yes,I´m testing now with mexican domain AP, but it still doesn´t connect
Rasika
capwap ports opened on the firewall ?
Yes, all IP traffic is allowed
Alejandro.Angon
After ugrade code to 7.6.110 and FUS, the AP has registered without any problem,
thanks.
silvio.lui
Hi... as you are splinting your broadcast domain, you should set the branch to get WLC answers via CAPWAP (UDP 5246 to AP controlling)  and considering use DHCP option 43 (converting the WLC IP to hex) and use it to allow the branch AP joining using CAPWAP features:
In the router facing the WAN link:
ip forward-protocol udp 5246
interface <AP_FACING>
encapsulation dot1Q <AP_VLAN>
ip address <AP_subnet>
ip helper-address <WLC_IP>
ip dhcp excluded-address 10.10.8.<start_reserved> 10.10.8.<end_reserved>
ip dhcp pool <AP_POOL_NAME>
network <AP_NET>
default-router <AP_GW>
dns-server <DNS>
option 60 ascii "Cisco AP c2800" --> to model c2800 if it's the case
option 43 hex f104.aaaa.bbbb.cccc --> f104.<WLC_IP_HEX_CONVERTED>
Silvio Silva
