Rehost Licence Wireless Lan Controller 5508
cesarhenao
regards
I have a question.
I have 2 controllers that work properly
The first has 50 licenses WLC CISCO 5508
The second has 110 licenses. WLC CISCO 5508
I would not use the first controller ¿I can move 50 licenses from the first controller to the second and be in total with 160?
Thanks,,
Abhishek Abhishek
The following link provides information on how to transfer “Adder” licenses from one WLC to another: http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ccfg.html#wp1880270.
It is not possible to transfer the base licenses (that come installed along with the purchase of the controller) to another controller. For further details about the Cisco Flex 7500 Series and Cisco 8500 Series platforms that support Right to Use (RTU) licensing, see the RTU Q&A.
7 Replies 7
George Stefanick
If you purchase the control as a 50 then no. If you purchased as say a 25 and added 25 more licenses then you could ask Cisco to rehost. But they may say box
if one controller is backup and has a minimum of a 50 lic you can put it into ha mode and this will make the controller go to 500 licens. But this is for back up only ..
Thank You,
But we have a WLC H. A.
We spare a controller 5508 and wanted to know if we could dispose of its 50 licenses to add to our active controllers
Abhishek Abhishek
Saurav Lodh
Level 7
Level 7
Similar discussion:
https://supportforums.cisco.com/discussion/11964716/wlc-5508-license-rehost
mohanak
One license can be registered only to one device. Contact the licensing team licensing@cisco.com to rehost the license
sobhardw
Please follow the below link on Rehosting the license :
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70ccfg.html#wp1880402
Seems like the links that were posted here doesn't work anymore. are there new links on the guide on how to re-host wlc license? Thank you in advance.
