remove interface Embedded-Service-Engine0/0 ??
selvas
Visitor
no ip address
shutdown
How do i remove the above config from my default 2901 configs? any hint??
M. Wisely
Level 9
Level 9
I'd suggest you read this discussion which answers the question:
https://supportforums.cisco.com/discussion/11184226/interface-embedded-service-engine00
Basically it's an interface created by the hardware rather than the configuration so can't be deleted
mohanak
Remove is not possible, you can disable the services.:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/services_modules/cimce/1-0/configuration/guide/CIMCe.html#wp1114760
