Replace WLC Mobility Group Anchor
jeff6strings
Level 4
Level 4
We have 2 5508 and 1 4402 WLCs and all belong to the same mobility group. The 4402 does not have any access points and does nothing more than serve as a mobility anchor for our public wireless SSID. We are planning to replace the 4402 with a new 2504 unit which will have the same configuration including IP as the 4402. Is there anything I need to do with the mobility groups when we remove the 4402?
Thanks for any help.
Jeff
Stephen Rodriguez
you'll need to add the MAC of the 2504 to the mobility group, and remove the entry for the 4402.
Out of Curiosity...how many concurrent guest users to you have usually?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Steve,
Thanks for the reply. We sometimes peak at 350 concurrent for a short time (couple hours) during the day.
Jeff
