Replacement of existing certificate
wim_depauw
Our wireless network uses a certificate that is generated by the ACS. This certificate is expiring with 3 months. We would like to implement a solution with a microsoft ca server but wwe have the following question.
Will the current certificate still be valid when we install the new certificate on the ACS server ?
Since we are not able to push the certificate to all clients at the same time we would like to avoid that the wireless network is unavailable for users with original certificate...
carenas123
Level 5
Level 5
If you are installing a server certificate that replaces an existing server certificate, the installation could affect the configuration of the CTL and CRL settings your Cisco Secure ACS. After you have installed a replacement certificate, you should determine whether you need to reconfigure any CTL or CRL settings.
If you are validating the server certificate in the clients, then what you will have to do is add the MS CA to the trusted server list and push that out via GPO to the clients. This way you can avoid any issues. If you are not validating server CA, then it doesn't matter what certificate you use.
-Scott
