Replacing AP1231G-E-K9 (LEAP) with new 1260, will it work with 350PCMCIA?
John Myhre
iam currently trying to replace AP1231G-E-K9 with new equipment / Cisco AP next generation  maybe?
The problem is that the system, that is going to use the AP is using aironet 350 PCMCIA adapter with LEAP.
If in fact we are going to use a new Cisco AP, will the new generation work with Aironet 350 Adapter and support LEAP?
please feel free to ask questions and suggest new configurations.
Thank you
Hi John,
the 350 supports LEAP.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6442/ps4555/ps448/product_data_sheet09186a0080088828.html
The 1260 I think too, it is shown in the config guide, so I think it is possible, pretty sure.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/scg12.4.25d.JA-chap11-authtypes.html
hope that helps, if yes pls. rate.
regards,
Sebastian
George Stefanick
+5 Sebastian for your home work!
The 1260 will support LEAP and your 350 series cards.
