04-14-2014 12:54 PM - edited 07-05-2021 12:41 AM
I need a report for all Power Inyector installed with a AP, how i have this information in a report?
please i need help
Solved! Go to Solution.
04-14-2014 01:12 PM
The is no way to detect if your using a power injector or not. There are commands to enable if your using a power injector, but that doesn't mean its not connected to a PoE switch.
That would be a manual process of going to each ap and looking.
04-14-2014 01:12 PM
04-14-2014 03:45 PM
You do an SNMP crawl. It will tell you if the APs on PoE or injector.
