Showing results forĀ
Search instead forĀ
Did you mean:Ā
Reporting problems with Cisco WCS
Lance Wendel
Level 4
Level 4
hi all,
I was wondering whether anyone has experienced the following symptoms on Reporting.
WCS Rogue AP reports do not run and show up as 'Expired'
this does not occur to all the Rouge AP  reports though (they are being created based on floor areas; one report per campus)
customer is using the following
WCS Version: 7.0.230.0
any idea on this, could this be a software bug?
thanks a lot
with kind regards,
Lancellot
Amjad Abdullah
The report expires when it is scheduled report and configured for some specific time. After the time passed the report expires. re-schedule the report time and change the start-date time of the schedule and that should resolve your issue.
Amjad
Rating useful replies is more useful than saying "Thank you"
