required code for 1252 with N
michael.lussier
Level 3
Level 3
I understand there are some issues with some versions of code not working with the 1252 and N.
Can some one clarrify this please. I'm not permiteed to run the latest code and that normally means that I have to run 2 revs back. currently I'm running 4.2.61.0 accross the campus.
20 Replies 20
hahaha. I see that now. Did you post the results?
-Scott
? Which ones?
Just saw your attachment..
-Scott
I looked at your results and it looks like you are getting around 30-35% on the wired. So i would say that is what your percentage should be on the wireless.
-Scott
Very interested in seeing what you have for other commands on the switch configuration. Also what version of WCS are you running ?
Hope this info helps.
-Doug
WCS 4404-100 for testing only
Product Version.4.2.130.0
Switch
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(44)SE, RELEASE SOFTWARE (fc1)
AP
Product ID AIR-LAP1252AG-A-K9
Here are the switch commands that were used. If you cannot get 20000 milli-watts the connection will not completely come up.
Switch(config-if)# inter range g0/1 -10
Switch(config-if)# power inline port maximum 20000
Switch(config-if)# power inline auto max 20000
WLC commands - These have to be done via the CLI. From what I hear there is a bug in the GUI that is being worked on.
(Cisco Controller) >config ap disable
(Cisco Controller) >config 802.11a disable
(Cisco Controller) >config 802.11a channel ap
(Cisco Controller) >config 802.11a txPower ap
(Cisco Controller) >config 802.11a chan_width <20/40_ABOVE/40_BELOW>
(Cisco Controller) >config 802.11a enable
(Cisco Controller) >config ap enable
* Resource management does not work with this currently. You have to manually assign the channels and levels.
Other info:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
