Reset Radio Interface Dot11Radio0,QBSS Value: 100%,Reset can be expected due to harsh RF
Peter Setaffy
Dear team,
Can you please help me with identify logs from AP?
I have some APs where can I find this logs on syslog.
May 3 13:08:53.259: %DOT11-5-QBSS_INFO: Reset Radio Interface Dot11Radio0,QBSS Value: 100%,Reset can be expected due to harsh RF
May 3 13:08:53.259: %DOT11-2-FAILURE_RADIO_RESET: Interface Dot11Radio0, reset due to transmitter seems to have stopped(6)
May 3 13:09:02.815: %EVT-4-WRN: Write of flash:/event.r0 done
May 3 13:09:03.423: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetPCI reset port 0
May 3 13:09:04.731: soap_pci_reconfig_radio: radio id 0
May 3 13:09:04.763: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
May 3 13:09:04.767: %CLEANAIR-6-STATE: Slot 0 down
May 3 13:09:09.663: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
May 3 13:09:10.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
May 3 13:09:35.539: %CLEANAIR-6-STATE: Slot 0 enabled
sh controllers Dot11Radio 0
Normal:
Code Count State When
10 53 STOP 20:50:41.783 UTC Wed Apr 21 2021
21 2 STOP 20:50:23.455 UTC Wed Apr 21 2021
27 1 STOP 20:50:41.711 UTC Wed Apr 21 2021
39 2 START 00:01:08.499 UTC Mon Mar 1 1993
40 1 STOP 20:50:41.947 UTC Wed Apr 21 2021
46 1 STOP 14:00:14.308 UTC Mon Apr 26 2021
56 4 STOP 14:00:12.872 UTC Mon May 3 2021
Failure:
6 2 STOP 13:37:42.632 UTC Mon May 3 2021
23 4 STOP 10:02:18.507 UTC Thu Apr 29 2021
Prefetch: Trigger Active: 0 Recovery Disabled?: 0
Its AP: AIR-CAP2702E-E-K9
WLC: 5520
AireOS: 8.10.151.0
Mode: FlexConnect
Uptime about 1 week, 5 days
Have you some experience with this msgs please?
Thank you
Peter
saravlak
first, these continuous radio resets are expected when radio observes High channel utilization from its environment.
what's the 2.4ghz antenna model/gain.
Anyway, in this condition 2.4ghz on this radio can't serve clients properly with 100% qbss.
Remedy options:
1)Is it high-density environment. how many 2.4ghz neighbors seen by this AP.
//If there're way too many 2.4ghz neighbors then disable some of them to avoid CCI.
2)Following are some generally suggested options.
//Reduce the power through RRM/manual.
//Disable lower data rates.
