Reset ssid configuration
r2kat
Level 2
Level 2
I just figured out that there is a new modern version of the ssid configuration site at Meraki.
But i still couldnt figure out how to reset an already configured SSID to the default settings or is this still not possible?
This would really helps to keep the environment clean and to have a better overview.
But i also dont want to reset manually each ssid i configured in all the different networks.
Or is there any other possibility to do this?
Best regards
René
aleabrahao
Meraki Community All-Star
An SSID cannot be deleted, only disabled, renamed, or reconfigured. Once an SSID has been customized, there’s no native way to wipe all settings in one action.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
5 Replies 5
Mark Elsen
  - @r2kat                 Review this thread : https://community.cisco.com/t5/wireless/ssid-reset-to-default/m-p/5472964
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
aleabrahao
joey.debra
I usually just put Unconfigured SSID # back and set it to disabled.
That is all that is needed to remove it from view if you have more than 5 or just don't let your eyes fall on it.
Philip D'Ath
There is no way to reset an SSID to its defaults.  It would be nice to have this option.
r2kat
Level 2
Level 2
Thank you all for the feedback.
Then its still the same like last year.
I just hope that they will add a simple 'default' button when they have already modified the view..
The main problem is still that the chance of a mis-configuration with a completely modified ssid is much higher, then reset it to default and then build it up by scratch.
I will send them a feature request.
BR
