Resetting a 2504 wireless controller
nh6we
Level 2
Level 2
Outside of the GUI, how do you reset a 2504 wireless controller back to factory settings.
If you can log into the controller, yes.  The command "clear config" will clear out all config.
Leo Laohoo
Other than GUI?
The CLI command is "clear config".
So will that command set it back to factory - as it was out of the box??
Leo,
   Thanks for the help
Chris
