restrict web management access for certain users
0600648902
Level 3
Level 3
I have problem to restrict web management access for only certain IP can access it. I have tried to user Access Control List which associate to management interface and interface for wlan, but no one can block such traffic.
For example, I want users in net 192.168.1.0/24 can access to wlc web management, and the rests cannot.
How can I do it ?
Thanks in advance.
amritpatek
Level 11
Level 11
Access lists should be used in "firewall" routers, which are often positioned between your internal network and an external network such as the Internet. You can also use access lists on a router positioned between two parts of your network, to control traffic entering or exiting a specific part of your internal network.
For the further details of the Configuring IP Session Filtering following URL may help you
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfreflx.html#wp1000871
