revert from LWAPP mode to autonomous mode
juanfalomir
Community Member
hello
I want to upgrade the ios ap-1240AG me to leave it in standalone mode. But I havesome doubts. What default ip should take my ap?
How should we be the tftp command to update the IOS on my ap?
I am using tftp server of windows xp.
Thank you very much.
dmantill
Level 11
Level 11
IF you are going to convert the AP using the mode button the AP will use 10.0.0.1 therefore you need to set up your PC to x.x.x.2 -x.x.x.20
However once it is converted the AP will request an IP address from DHCP server.
