RF And Bandwidth
support47
Community Member
What RF spectrum and wifi signal power
support47
Community Member
How can i improve signal power in MR access point
Philip D'Ath
Meraki Community All-Star
Stand closer to it.
CMR
The signal power of a Meraki AP can be controlled through a profile or overridden manually for one AP. However there are limits based on local regulations and the exact AP model and connected antennas that may not allow the maximum power to be realised as seen highlighted below:
The profiles are under Wireless / Radio Settings / RF profiles
The overrides are under Wireless / Radio Settings / Overview - check the AP and click on the Edit Settings button.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
Philip D'Ath
Could you rephrase the question?
