RF clients loos IP connection to AS400 trught Access point Linsys WAP11
mbanach
I´ve and AS400 R4V4 running on VLAN A. On VLAN C I´ve 10 DLINK Linksys WAP11 access points connected.
Both VLANS are running over CAT35xx family switches and the conection between them is made by a 2621 router (using and ISL link to swicthed network).
I´m using Telxon/Symbol 5250 IP based emulation wireless terminals. When I use few RF terminals (1 to 4) there is no problem, but when I try to use more (20 by example) over a closer area the 5250 emulation clients program loos the IP ocnectivity.
I´ve reviewed all the AS400 configuration, the catalysts configuration and by the way I´ve decreased the ARP router refresh over VLAN C subinterface to 10 seconds, but I couldn´t solve the problem. Do you have some advice or sugestion ?
beth-martin
Level 5
Level 5
I’ve seen a few posted issues with the LinkSys wireless products. I’d start there.
