Roaming between 2 controllers
cuongphan
Frequent Visitor
Frequent Visitor
I have:
1 Wifi Controller: SSID Staff (Subnet 192.168.10.024)
1 Wifi Controller: SSID Product (Subnet 172.16.10/23)
All are centralized control at DNA Center.
And 802.1x authentication (ISE and Radius on window server).
Between the SSID Staff vs Product interference area, some users with the phenomenon will prioritize connecting to the most recently connected SSID, even though the signal of that SSID is very weak.
When the signal connection is so weak, the ISE will lock this user.
I have removed the auto-connect SSID mode so that when starting the laptop, the user will automatically select the SSID in the area where he is working and has a strong signal.
Is there any way to fix this error, because there are so many users, I can't tell them to turn off auto connect automatically.
6 Replies 6
Mark Elsen
 - Consider this advisory : https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_Cisco_Wireless_LAN_Controller_Configuration_Best_Practices.html#concept_C1F0E5E69F294DA6851DDE5B783ECE42
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thank you very much
Hi @cuongphan
 If user can connect to both SSIDs I believe you can consider to have only one. Is there any reason for two SSIDs?
Why dont you put both SSIDs in all area?
- 2 SSIDs will apply 2 different policies so it is imperative to keep them.
- 2 SSIDs on both areas will lead to roaming between 2 WLCs and Radius, so ISE Block is frequent.
Arshad Safrulla
I am very interested in knowing how do you achieve "When the signal connection is so weak, the ISE will lock this user".
Why do you have AP's registering to 2 different controllers in the same vicinity. As the first thing I would consider consolidating all the AP's in to one WLC if it allows. Then which SSID to connect automatically is often decided by the client, so unless you have a MDM solution like AnyConnect or Meraki I think it would be difficult to achieve this.
Another way of doing this is if both the SSID's are authenticating against ISE, you can use ISE to blacklist the Staff devices from connecting to the Product SSID.
https://community.cisco.com/t5/network-access-control/blacklist-for-registered-corporate-mac-s-on-guest/m-p/3503958
I am thinking of mobility group solution between 2 WLCs. Thank you.
