roaming between three controllers
Mohamed Sayed
Level 4
Level 4
hi all,
I have three wireless controllers each one in separate subnet, each controlller has set of APs connected on it.
I configured mobility group between the three controller but when moving from specific AP on specific controller to another AP on another controller connecting by cisco wireless ip phone 7925 the call is dropped and the phone re-register again.
when roaming between different APs on the same controller, no problem occurs.
then the problem is in roaming between different controllers each one in different subnet.
appreciate your support.
please advice.
15 Replies 15
Rasika Nayanajith
It seems like L3 roaming is not working in your environment. Ideally even client move to different subnet WLC, he should be able to retain the IP & keep the continuity of the connection.
It is good if you could post "show mobility summary" output of your controller to see the mobility is up & running.
Rasika
**** Pls rate all useful responses. Each time you rate a response Cisco will donate $1 to Kiva ****
