Roaming from AP to AP on same SSID
JDMJeffy84
Hi Guys,
I have an issue where I have an AP in one room and another in another.
When I walk from one room to the other, I lose signal but manages to see the SSID and join.
But, I cannot seem to surf the Internet, I have to manually disconnect and reconnect.
Any suggestions? Normal wireless routers I reconnect seamlessly without any manual disconnect & reconnect.
Currently using cisco 5508 and ap2600
8 Replies 8
George Stefanick
Can you share what clients are doing this? Are all of them ? Is there anything fancy about your config ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
general browsing George, yes it happens to all clients.
Config is very basic, I'm just wondering if there's a setting I missed out
Log into the WLC cli and do a client debug and reproduce the problem. Then post the results ..
Hi George sorry for late reply, I don't have the results with me but I ran a few tests with debug but nothing stood out of the ordinary.
What I found strange is that if I use a laptop and leave a continous ping and walk from one AP to another AP I can see latency jumps and a few timeouts but ping still go through. But I am unable to access the Internet unless I disconnect and reconnect.
Authentication on L2 and L3 is set to None so it shouldn't be that.
Can you post the debugs ?
Sorry still no debugs, but it looks like it is not Roaming issue.I can conduct continous ping to 8.8.8.8 -t from AP to another AP
But if I ping a website for example www.facebook.com
works fine roaming
But if you access the URL via domain name or IP it fails.
Checked the ASA firewall I get SYN Timeout and deny TCP...
If I disconnect SSID and reconnect... traffic goes through... something wierd is going on
What firmware are you running?
What radio are you seeing this happening?  802.11 b/g or both?
What is the signal strength indicator from the PC?
How updated is the driver of your wireless NIC?
I will post when I conduct more tests.
leelaohoo, running latest 7.4.100
