Roaming issue
pete.pmp
Frequent Visitor
Frequent Visitor
Hi, I am facing issue with some WLAN clients roaming. In case they want to reassociate to different AP, client is dropping. I started debug at WLC, but there is nothing in WLC debug logs during roaming period.
I have pcap logs and I found that client sends probe requests, authentication requests, association and reassociation requests at lower speed (1 Mbit/s) than we use as mandatory for management traffic in 2,4 / 5 GHz band.
We use 6 Mbit/s as mandatory for management frames. Speed of 1 Mbit/s is disabled at WLC.
Question is what happens when client is connected to the WLAN and sends reassociation request (at speed 1 Mbit/s) to different AP with mandatory speed set at 6 Mbit/s for management traffic?
I suppose that it could not be a problem for probe requests because client does not know about policy set on wlan controller or AP but could it cause any problems during association or reassociation to WIFI AP?
P
Leo Laohoo
What kind of clients are these?
What are the exact model of the wireless NIC?
What version of wireless NIC drivers are they on?
Leo Laohoo
We are having good results with 1562.
I would recommend 1562I because it has good radiating patterns suitable for this scenario, however, be warned of the power requirements (39w PoE).
Rasika Nayanajith
Typically once client send Probe Request, AP respond with a Probe Response. In that Probe Response frame, AP inform client what data rates it is supporting. I would check Probe Response frames in your case & ensure AP inform clients its supported data rates properly.
Have a look below post
https://mrncciew.com/2014/10/27/cwap-802-11-probe-requestresponse/
Therefore Association Request should go in a data rate AP supported, otherwise client will not able to associate.
https://mrncciew.com/2014/10/28/802-11-mgmt-association-reqresponse/
Same goes with Re-association Request (roaming scenario), it should go with AP supported data rate.
https://mrncciew.com/2014/10/28/cwap-reassociation-reqresponse/
Regarding those data rates, if you look at below table you understand 1,2,5.5,11 Mbps use DSSS (to support 802.11b compatible clients). Ideally you should disable these data rates on your AP (as long as your clients are 11g capable in 2.4GHz). Check your client capabilities as well.
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob41dg/emob41dg-wrapper/ch3_WLAN.pdf
Rasika
*** Pls rate all useful responses ***
