Roaming-related questions
felix3075
hi
1142n model in use.
This is needed because the roaming settings off, while also being used to move a large number of equipment ap
I would like to know the settings that can optimize roaming.
Leo Laohoo
This is one of the most common questions asked.  Same question applies:  Efficiency of roaming can be affected by a lot of factors.
First question everyone will want to ask is:  Was a proper post- and pre- wireless site done?
George Stefanick
Hello Felix,
I hope you are well. Here are a few things.
1) WiFi clients dictate roaming.
2) You could influence roaming with proper RF designs, controller configuration etc.
3) Security wise PSK and 802.1X enterprise, 802.1X has additional overhead if used on WiFi if the device doesn't support OKC and 11r for example.
Its a complicated subject to be honest ..
