Roaming with 3 cisco APs
pedromoutinho
I need to install a wireless network with 3 Cisco APs. Two of them are fix the other are in a mobile vehicle. I need that the mobile AP is configured for roaming between the two fixes AP. This is a possible configuration? What APs should  I use?
Sandeep Choudhary
You want to use AP with WLC or AP alone ?
I will say use 2 Cisco ap as in normal mode and use 3rd AP as WGB.
mount this WGB on mobile vehicle. This WHB will communicate with these 2 APs.
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/68472-configure-wgb-00.html
*** I will recommend to use 1702 Cisco AP.
Dont forget to rate helpful posts
