02-24-2003 12:34 PM - edited 07-04-2021 08:31 AM
I have installed several WLANs over the years using non-Cisco equipment. However, Ive seen-the-light and have deployed a WLAN using two Aironet 1100 access points. My question is how do I allow my clients to roam between the two? In my previous installations this was a built-in feature of the hardware, but I dont know how to do this with the 1100. Your help is greatly appreciated!
02-24-2003 06:58 PM
Hi ,
In the wireless lan there are two kind of roaming ,
a) layer2 roaming and b) layer 3 roaming .
Layer 2 roaming is supported by all Cisco AP and it is defined in 802.11b standard .
If you have latest ACU and Radio fimrware on the Cisco Client card you will see there is option periodically scan for better AP . You can check or uncheck this option .
Layer 2 romaing is ON by default , you do not have to configure anything on APs. Make sure SSID and Ip address subnet is same .
Layer 2 romaing depends on signal stregth , # of hops from backbone , Loss of beacon packets etc ....When client finds better signal strength from another AP , it will roam to that AP . Two AP will talk IAPP protocol for smooth roaming .
For Layer 3 roaming you need mobile ip stack on PC and Home Agent / Foreign Agent .
Cisco AP now supports proxy mobile ip , it will proxy for client so you don't have to install proxy mobile ip stack on each client . This allows to do layer 3 roaming .
04-16-2003 05:51 AM
I know that the AP1100 can work in repeater mode, so to extend coverage where cable can't be laied. What i really think would be great is to make the AP1100 work in repeater mode trought the wired interface without wasting radio bandwith !!
Any thougts on this ? Can it be done ?
