Roaming with APs.
johnleeee
Level 6
Level 6
Hi all,
I have very basic question related to
roaming of WiFi clients between two
APs. Should I configure both with the same configuration and roaming is done automatically? Or, should I do anything
more. I set both to Access point root.
BR
jl
jolmo
Level 9
Level 9
Hi John
You are right, configure both with same security settings and roaming is done automatically. Both can be AP roots.
If your client devices are going to use voice or other time-sensitive applications, Cisco recommends using CCKM (Cisco Centralized Key Management) in order to roam from one
access point to another without any perceptible delay during reassociation.
Hope this helps
Hi jolmo,
thanks for answer Im glad..I will try CCKM too.
regards
jl
