Rogue access point on wire auto port shutdown
mwissa_2
I am unclear on the documentation. Can Cisco Prime auto shutdown switch ports that have rogue access points connected to it? The auto switchport trace feature doesn't seem to be shutting down the port on the switch. I need to know if there is a way to automate the port shutdown.
Attached is a document with my current configuration.
Leo Laohoo
Not sure but you can configure the WLC to auto-contain a rogue-on-a-wire.
Saurav Lodh
Level 7
Level 7
you can disable the switch ports, ( Wired Rogue Access Point Switch Ports). Please refer to the switch port tracing and "switch port tracing details" from the below document.
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.2/configuration/guide/admin.html#wp1603927
For "Rogue containment " by controller, as what said by Leo, refer to
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080b40901.shtml
aesmaeil
Today I had a chance to test this feature, I dont see any options to automatically disable ports that found by SPT. I think administrator need to manually disable the ports. Please correct me if I am wrong.
same exact question i have now. but seems like i dont see it as an option on cisco prime to auto shutdown the port. im using prime 3.2
