Rogue Detection Minimum RSSI feature with wIPS
ReFeeL
Does the Rogue Detection Minimum RSSI feature work with wIPS as well?
Suppose I set the Rogue Detection Minimum RSSI to -80. This means that the AP will detect rogue with a signal strength higher than -80 and will display it on the WLC.
Does this value affect wIPS as well? Let's say an attacker tries Disassociation / Deauthentication Flood at -85 range on WLC, will it be visible?
ReFeeL
I have tested and concluded that if the Rogue Detection Minimum RSSI is set to -80
The AP will detect rogues with signal strength higher than -80 and will display them on the WLC.
Simulates an attacker in position -85 and sends DeAuth. AP can detect and send DeAuth information to display on aWIPS on WLC.
ReFeeL
