RRM DCA algorithm and DCA sensitivity
jsmbrown
Level 2
Level 2
Can anyone explain in detail the way DCA works? I have read the RRM document - http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#dca_algorithm
many times and I still do not understand DCA fully. It would help to have examples as well as to know when DCA sensitivity setting of high would be recommended.
Joe
didyap
Level 11
Level 11
DCA Sensitivity Level The configured DCA sensitivity setting: low, medium, or high. This setting determines how sensitive the DCA algorithm is to environmental changes such as signal, load, noise, and interference when determining whether to change channels.You can use the config advanced {802.11a | 802.11b} channel dca sensitivity {low | medium | high} CLI command to configure the DCA sensitivity level.
