RxSOP values?
SondreSandberg
Level 3
Level 3
I'm looking into tweaking the RxSOP values, but I can't figure out what the "auto" value means.
Anyone who can help me understand this?
For reference I'm looking at these settings on a 8540 controller, v8.5.161.0 and 2802e AP's.
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/hdx_final/b_hdx_dg_final/high_density_experience_features_added_in_release_8_0.html
  The RX-SOP default threshold value is Auto, which means that the RX-SOP threshold is set to the radio’s default value.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
JPavonM
You can check this on a per-AP basis:
ap3700#sh controllers dot 0 /1
interface Dot11Radio0
Extended Radio Parameters:
Beacon period (not supported), range (not supported)
Ext Conf flags: 1
Mcast rate 0 Mbps (Disabled)
RX sensitivity -78 dB (Enabled)
CCA threshold -0 dB (Disabled)
Coverage Report Interval - 90
-Jesus
*** Please Rate Helpful Responses ***
