Save WLAN Config per CLI on 3850 Switch
j.greza
Visitor
Hello Experts,
I have a question for a 3850 Switch with WLAN Configuration.
How can I perform a data backup via CLI for the WLAN Configuration.
On the configuration file with "show run" no Access Point configurations appear.Only in the dot11 parameters I see the Config . Are these included in the running-config?
Of course it is possible to save  the Configuration about wireless WEB GUI.How is the best way to perform a backup using CLI or PI.
Jürgen
Freerk Terpstra
Level 11
Level 11
Access-point specific settings will be saved on the access-point itself, that is the reason why you don't see it in the configuration. The output of a "show run" combined with installed certificates (don't forget the private key), vlan.dat file on the flash and also uploaded web files should be sufficient.
Please rate useful posts... 🙂
