Searching for RP-TNC Antenna Extender Cables
Zelliaind
Hi all,
I'm trying to find RP-TNC female to male extender cables going from a Cisco Air 1852 to a AIR-ANT2544V4M-R antenna. We're mounting one of the AP's on the ceiling of a warehouse and have the antenna below (6-10 feet away) mounted inside a freezer unit with the cables coming out the top with the hole sealed around the cables. There is only about six inches of cable left coming out of the insulation that was placed around the cables and as such we need extension cables to reach the AP.
I've tried looking around but haven't found anything substantial. If anyone can point me in the right direction, I'd appreciate it. Thanks!
As Sam said check out Ventevinfra but if you need to order direct from Cisco for what ever reason:
Cisco has their own low-loss RF cables you can order from them as well
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
AIR-CAB005LL-R - 5-ft low-loss cable, one RP-TNC plug, one RP‑TNC jack
AIR-CAB020LL-R - 20-ft low-loss cable, one RP-TNC plug, one RP‑TNC jack
and a couple of bigger lengths.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
