Secure Wireless network
phiz.petry
I have a wireless network (9 Cisco AP 1200) connected to the enterprise Network (Cisco Catalyst Switch).
The wireless network is connected to an another VLAN and i have a router on stick for inter vlan routing.
It works well, but it is difficult for the support to change any configuration (IOS command).
Does anyone know a solution for easy management ?
I thing about :
Firewall between the 2 networks (Is it much easy to manage ?)
or
WLSE ?
Example for most current task for managing :
Change user right on witch server he can access.
(before i use IOS Access list)
thanks for your help
Not applicable
The following document should exlain what can be achieved with a WLSE,
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_user_guide_chapter09186a00801f4f6b.html
