Security vulnerability of open authentication when using Splash page?
We are using Active directory combined with Splash page.
I must use open authentication to use Splash pages.
Open authentication does not allow the use of WPA encryption between the PC client and the AP.
Is this a security vulnerability?
What steps do we need to take to ensure that we meet the requirements of wireless security?
aleabrahao
Meraki Community All-Star
It is not necessarily a security risk, as despite being an "open" network you will be requiring authentication. Of course, you won't have encryption, which is exactly why this is a type of network most suitable for Guest users.
https://documentation.meraki.com/MR/MR_Splash_Page/Integrating_Active_Directory_with_Sign-On_Splash_Page_For_MR_Access_Points
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
ConnorL1
Meraki Employee All-Star
Whilst your wireless traffic isn't encrypted, the HTTPS session between your client and the Splash Page server is.
If the SSID is primarily for employees/staff/trusted users, I would leverage 802.1X RADIUS instead. Yes the user won't get a pretty splash page, but it would then ensure the wireless traffic is encrypted.
Philip D'Ath
You can use a PSK when using AD splash page authentication.
You could also get adventurous if you have WiFi6 APs and try our OWE encryption.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/WPA3_Encryption_and_Configuration_Guide
