Seeking help...
Steve Benner
Community Member
Hi folks,
First time out here on the Cisco discussion board and seeking a little help...
My company currently has a WLC-4402-12-K9 in house and is up and running without issue (except that we're out of WAP licenses).
With that said, I finally got management to break down and upgrade to a 50 since we are expanding these days (yeah, there's a shocker!)  With that said, I need to find out the easiest way to pull the configuration off the old 4402-12 and roll it onto the 4402-50.
I'd really appreciate the help, my boss tasked me with this and although I can speak Cisconese without issue, this little beast makes me a bit "apprehensive" to say the least.  Foreign territory!!!
Thanks in advance.
Steve
6 Replies 6
Leo Laohoo
Firstly, you can no longer buy the 4400.
Secondly, I'd recommend you consider a 5508 with AP license of 100 instead of just 50.
Steve Benner
Community Member
Thanks for the advice, however I did buy the unit from a hardware reseller (so I got that one covered).
Now that I have the device, I seek the wisdom of all to configure this device to be an in-place upgrade to my existing 4402-12.
Thanks again though for the advice, next time I'll consider it.
Do you want to REPLACE your 4402-12 with a 4404-50 or do you want to run them in tandem?
If you want to run the two in tandem, copy the config of the 4402-12 and change the IP addresses (except the virtual IP address).
If you want to replace, then copy the config across the 4404-50.
Hi Steve,
Yes you can copy configs from one 4402 to another. Check this link :
Link:
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_managing_ctrlr.html#wp1063850
You can also edit the config file ( post 5.2 code ) to change IP address etc.
I would recommend to move to 7.0.220.0 first on 4402-12 as in previous releases there were many things not copied when you backup WLC config..
Thanks..Salil
All -
Your advice was right on target.  That's exactly what I needed to do and it worked like a charm.
Hats off to you...  THANKS!
Steve
Hi Steve,
Can you mark the question answered so others can benefit as well while they search .
Have a good day.
Thanks.Salil
