Service Module is trying to recover from error - Please help
thags
HI Guys
I am currently installing a NM-AIR -WLC 6  wireless module in a 2811 and its giving me the follwing errors below and status
I have checked the troubleshooting pdf and says might be possible hardware error ,but before i go down that road would like to know if any of the engineers have solved this problem
Info about router and module is as follows
Router#service-module wlan-controller 1/0 status
Service Module is Cisco wlan-controller1/0
Service Module supports session via TTY line 66
Service Module status is not available
Router#
Trying to reset Service Module wlan-controller1/0
*Mar 28 21:49:06.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface wlan-controller1/0, changed state to down
*Mar 28 21:49:26.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface wlan-controller1/0, changed state to up
Router#
Service Module is trying to recover from reset/shutdown
sh version
Router#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T17, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 07:41 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Router uptime is 28 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.T17.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ0932701R
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Wireless LAN Controller(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router#
thags
HI Guys
And it gets worse I am now getting the following error
Service Module is failed
regards Thags Govender
Your SM is dead.  There's nothing you can do about it (including saying a prayer).  Please contact Cisco TAC and get the faulty component replaced.
Stephen Rodriguez
Time to call TAC and get a RMA
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HI Guys
Thanks for your confirmation , well we have brought some modules back from the dead at times thought we could do the same here ,guess not.
Thanks guys
TAC here I come
