Setting a password for user access on AIR-SAP1602I-A-K9 running 15.2(2)JB2
grams
I am trying to assist a group with setting up their AIR-SAP1602I-A-K9 stand alone WAPs.  I would like to know how to set a password for clients to access the wireless network through these units.  I have been spoiled with our controller based WLAN.
6 Replies 6
Stephen Rodriguez
If you are doing it from the CLI
dot11 ssid Test
authentication open
authentication wpa version 2
wpa-psk ascii 0 "your key here"
Interface Dot111Radio 0|1
encryption mode ciphers aes-ccm
ssid Test
If you call a VLAN under the SSID, then you need to call a VLAN with the encryption statement under the radio interfaces.
If you are doing this from the GUI:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_10b_JA/configuration/guide/scg12410b/scg12410b-chap11-authtypes.html
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank you Steve for the quick reply.  I had a problem with the 'authentication wpa ver 2' command.  My auth options for the ssid are;
Hallway(config-ssid)#authentication ?
  client          EAP client information
  key-management  key management
  network-eap     leap method
  open            open method
  shared          shared method
So I am going to check out the link you provided for more info.  Thanks again.
ack! sorry about that
I missed the key-management command
authentication key-management wpa version 2
and that is for AES to get the 'n' and 'ac' rates.
HTH,
Steve
HTH,
Steve
Steve,
Thank you again.  The commands worked.  I still need to find the command reference for these units for future requests.
this should work
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15_2_4_JA/command/reference/cr1524JA_Book.html
Steve
HTH,
Steve
So the link just brings me here.  Would you know a site that has CLI commands for the AIR-SAP1602I-A-K9 Version 15.2(2)JB2?  I didn't have much luck in my search.
