Setting the location in 5760
Teamitlead
I am trying to find a way to set the "location" information in the WAPs that are connected to the 5760. When I try to make the changes manually via the web interface, the changes don't stick. I have not found out how to make the changes via CLI. Any assistance in figuring this out would be greatly appreciated.
Saurav Lodh
Level 7
Level 7
CCX Location Measurement Q – Default is off; enable if you use the CCX location features:
ap dot11 24/5ghz rrm ccx location-measurement <cr>
Use the no form to disable.
Refer
http://www.cisco.com/c/en/us/td/docs/wireless/technology/5760_deploy/CT5760_Controller_Deployment_Guide/Radio_Resource_Management_Configuration.html
I tried the steps outlined, but run into an issue at the ccx line. When I type that into the 5760, it gives me an error message stating unrecognized command. The options given for after the rrm are:
channel-update
dca
grouping
txpower
