04-23-2014 11:05 AM - edited 07-05-2021 12:43 AM
04-24-2014 09:28 AM
What are you changing? The management interface VLAN tag?
Keep in mind that the WLC is a dot1q trunk, so if you set the management interface VLAN tag to the switchports native vlan, traffic will get dropped.
HTH,
Steve
04-24-2014 09:46 AM
Thanks for the repose. The MI is on port 1. I am wanting to assign it to port 2, which is directly connected to the ISP router.
04-24-2014 09:51 AM
Why are you wanting your management interface to go to the ISP?
the AP's are on the internal network, and if you put mgmt to ISP, you won't be able to manage the WLC, nor will the AP be able to join.
Steve
04-24-2014 09:54 AM
Port 1 is my Mgt interface which connects to a cisco 3850. Port 2 goes to the ISP device.
04-28-2014 07:06 AM
Ok, then I'm confused
"When I change it to different VLAN ID, it does not work
What doesn't work? what VLAN are your changing and where?
Steveß
06-24-2014 03:31 AM
Go on below link, it possibly will be helpful for you.
https://supportforums.cisco.com/discussion/11585281/2504-wlc-and-2-vlans
