setting up AP SSO using 5508 controllers located in two different buildings , using a layer 2 connection between the two buildings
atifali.zaidi1
can i setup ap sso without using RP ports connectivity on 5508 controllers which are located in two different buildings , when the two buildings are connected by a layer 2 port-channel using single mode fiber
controller 1 - core switch ---------------------------------layer 2 port-channel -------------------------------------core switch 2 - controller 2
i dont have the option to use , RP port connectivity .
please advise how this could be accomplished ?
Scott Fella
The RP has to be connected. I have had customers do this but created a layer 2 code mnection just for the RP interface. Since you already have a layer 2 connection it seems to me that adding a vlan across shouldn't be an issue.
-Scott
-Scott
