setting up guest vlan
musumani.woods
Community Member
I have a 4400 controller and 10 1250 access points all being controlled via the controller.
I already have an ssid using 802.1x encryption. I need to setup a guest ssid but I cannot seem to find the right documentation related to my controller.
Can anyone help
6 Replies 6
andrew.prince
Level 11
Level 11
Musumani,
What version of software are you running on your WLC?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807810d1.shtml
Look through that, it gives ACL examples for guest networks. This also assumes' that you have the correct trunking on the switches, VLAN interfaces on the WLC and everything else in the SSID side. This also assumes that the design is solid as well.
First, what are you trying to achieve with the guest network. Do you want a webauth page, open encryption.....
-Scott
webauth page
4.2.61.0
For the version of software you are using, below is the configuration guide, it has everything you need:-
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/ccfig42.html
HTH.
