Setting up WPA on 1130AG
omgjames1
Can somebody walk me through setting up WPA or WPA2-PSK on a Cisco 1130AG?
Do I need a server to accomplish this?
11 Replies 11
Surendra BG
Using GUI..
SSID manager >> Configure the SSID >> MAP the VLAN if required>> enable the Radios >> Key Managament >> Mandatory >> Check WPA-PSk >> Enter the KEY >> Apply
Encryption manager >> select Ciphers TKIP >> Apply
Interface configurations >> G-radio >> Enable >> Apply.
Using Cli
dot11 ssid
auth open
auth key mana wpa
wpa-psk ascii
vlan #
guest-mode
Int dot11 0
encryption vlan # mode ciphers tkip
no shut
ssid
exit
corresponding sun interface configurations are required..
https://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#pers
No need to have the Radius server if we are using the PSK. (Personal)
Surendra
Surendra BG
the GUI is different on a 1130 vs. 1300.
I do not have Key management or the option to click on WPA-PSK only WPA, also, I do not have the option to select Ciphers TKIP.
Also I am attaching the config of the AP
GUI is the same.. in the ssid manager, exactly if we scroll down to half the screen we can see key management.
Similarly if we click on Encryption manager we can see "chphers" i request you to check the link which i posted in the previous post.
Whats is the model number of the AP? is it LAP1131 or the AP1130?
'Surendra
Surendra BG
it is AP1131AG-A-K9
here is a screen shot of the Encryption manager page.
dot11 ssid cgap1
authentication open
auth key-mana wpa
wpa-psk ascii
guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid cgap1
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid cgap1
dfs band 3 block
channel dfs
station-role root
bridge-group 1
the above config changes will help us.
Surendra
Surendra BG
Please try with different browser.. if this doesnt work then i request you to upgrade the IOS to the latest
by downloading from the cisco.com
Surendra BG
here is what I have so far, but I cannot get to the internet via the AP, I do not even get a screen to type in a key.
Any thoughts?
u have not configured the WPA authentication from the SSID manager.
I request you to configure the same.
Surendra BG
Under Security > Encryption Manager > Encryption Modes you will need to set the mode to "Cipher" > AES-CCMP. Next, proceed to the Security > SSID Manager, choose your SSID, and scroll down the screen. I forgot the exact name of the sub-section, but you'll need to set the first drop-down menu to Mandatory, check the WPA box, and select the version of WPA you wish to use from drop-down menu.
If you are missing any of these sections/options, upgrade your AP firmware to the latest available version from Cisco.
