Setup Mobility Express using 3802I's
TomBombadil
Community Member
My company is spinning off my department and I am inheriting a network that will be trashed in a month. they are cutting all ties. I need WiFi working and have a dozen 3802I APs to replace the 3502's. How do I get Mbility Express working to
 First you need to know how was this 3800 AP being used. Was they in a WLC? If there were, so they must be running capwap protocol and you need to convert it to mobility express.
 This video is for 2800 but the process is similar:
https://www.youtube.com/watch?v=EtmGDmRl4lU
You need to be able to download software from cisco site.
You can follow this guide to setup the network after converted. One AP will act as Wireless Lan Controller and the others will join the WLC as subordinate.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/84/user_guide/b_ME_User_Guide_84/m_get_start.html#topic_44E7F479DE7742488973ECC6D1C07067
TomBombadil
Community Member
I have 10 AP's i want to connect at my site. what do I do to the other 9 AP's?
