sh power inline
Islam Sallaj
Level 2
Level 2
Does anyone know why my aps are showing up as IEEE pd devices and others are AIR-LAP1142N-A-K9?
I find when they show up as IEEE they do not join to the controller. However now I am see that some that do show up as IEEE will join ok...however might not be stable...
Any thoughts?
Izzy
8 Replies 8
Leo Laohoo
Mostly it's because of faulty cabling.
Can you specify exactly what the model of your switch is.  There could be a chance you could run a TDR.
TDR?
Running ws-c3750-48p 12.2(40)se that is the switch these aps are connected to
ws-c3750-48p
Just want to make sure you didn't have a type-o here, but, the switch in question is a FastEthernet model and NOT a GigabitEthernet model?
Is there any switch with a GigabitEthernet copper port?  PoE or not doesn't make any difference.
TDR?
Yes.  TDR.  Read the link I've provided in my first post.  It'll give you a lay-man's-term of what TDR can do and help you in determining possible Layer 1 issues.
I don't see a link on your first post...using the iPad app...assuming there is no issue with that app...
The switch is fast Ethernet...I do have copper ports available I could use if needed to troubleshoot. For now however we are using fast Ethernet for all our ap communications. Is this an issue of any sort?
Are on a very old version of code so that is why I question a bug of some sort.
Izzy
Ok read a little bit regarding TDR... Not sure I have that tool here. Will have to check with the many fluke tools we have to see if we can test for TDR....
Maybe a tac case is needed here...
Izzy
Here's the link:
How To Use TDR
https://supportforums.cisco.com/docs/DOC-18983
For the 3560- and 3750-series family of switches, TDR is supported in the GigabitEthernet copper ports ONLY.
Almost all major Enterprise-class switch manufacturers now include TDR.  So you don't need to purchase a Fluke DTX-1800 unnecessarily.
I'll take a look at that doc...thanks...
All our 3750s are 10/100 copper. Have gig modules available that I can throw a copper gbic into....however it seems like you are saying it has to be copper gig port...not Sfp port...
Izzy
That's correct.  GLC-T and/or GLC-TX is not supported.
