Simple M'Cast issue 2504
Tarik Admani
I have a simple multicast setup that I can't get working. I have a Cisco WLC 2504 on version 7.4.110 (tried with 7.4.100) with one AP connected (3502). I have two SSIDs (psk limitation on apple tv) that point to the same interface with a default mdns profile attached to it. What I can not understand is why my airplay icon wont light up on my mac osx. When I connect through my corporate network (embedded LWAP on an dmvpn spoke) I can see my corporate apple tv just fine.
I ran a packet capture and debug mdns all and I see the reply with my apple-tv sent back to the my laptop, both mdns replys look fine for the apple tv service. I am a little confused at to what is the issue. The clients default gateway for both the macbook point the svi on my vlan, and just for grins I have ip pim sparse-dense mode configured.
I also tested with an ipad and i get the same results.
The corporate controller I tie back into is a 5508 that is on version 7.4.100
If there are any debugs I can provide let me know, I can clean the screenshots if anyone wants to see the packet capture. I wanted to ask to see if there is a simple setting I may be missing.
Tarik Admani
2 Accepted Solutions
Scott Fella
Make sure AirTunes service is enabled. That is what AirPlay uses in the later code versions.
-Scott
Yes, Since iOS 6.0.x onwards you required this AirTunes service in order to get Apple TV working with those.
Below post may help you as well
http://mrncciew.com/2013/03/27/configuring-mdns-on-wlc-7-4/
Rasika
**** Pls rate all useful responses ****
Scott Fella
-Scott
Rasika
Thanks for the help guys that is what it was.
Tarik Admani
