Simple Phone Questions
mbbristol1
Few quick questions - We have all CISCO VoIP equipment and just want to know what the best option is for a compatible cordless telephone with multiple handsets?   Please help....Thanks!
Hello mbbristol1,
It actually depends on your requirements. Do you have any specific features that you're looking into? You may want to check the Cisco SPA302D. This will give you the convenience of a cordless on-premises mobility solution for VoIP services. Please refer to the link for more information.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spa302d-multi-line-dect-handset/data_sheet_c78-717757.html
Hope this helps!
Let me know if you have additional questions.
Kind regards.
