Simultaneous RTOs in 2 differnet Links
yparashar
Community Member
Hi all,
I have following setup:-
Cisco 3600 series router-Remote APG Modem-Local APG Modem-D-Link 8 port switch-Local Cisco Aeronet350 Series-Client Aeronet Access Point-Client local Network.
There are 4 others network running with same devices connected to D-Link 8 port switch.
The problem which i am facing is that am getting simultaneous RTOs on only 2 Links and other network are working absolutely fine.And RTOs sometimes are 4,5,8.In both Links RTOs are coming at the same time.
I want to know wheteher this problem is RF or Network.Wht can be get done to rectify the problem. And wht can be the solution.And wht kind of software is best to monitor.
Thanks in advance.
Yogesh Parashar
0 Replies 0
