Site Survey with an LWAP?
mscherting
I need to survey a new building for wireless.  Actually it's an old nursing home.
In the old days I would setup an IOS AP as a DHCP server on a telescoping pole mounted to a cart.
Can I convert an AIR-LAP to IOS and do something similar?
How do you all do surveys for LWAPs?
Thanks!
Scott Fella
Yes you can convert the AP to lightweight and vice versa:
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
6 Replies 6
Scott Fella
Scott
-Scott
Great!  Thanks!
I know I can go from IOS to LWAP but I wasn't sure if there is a restriction on converting an AP purchased as LAP to IOS.
There is not... I do this all the time and your good:)  Just make sure you can download the code.
Scott
-Scott
Is this valid for a CAP-3602i as well?
You just need to make sure your CCO has entitlement to download the image... you should be able to keep both image on the AP and then just switch the boot parameter of the AP.
Scott
-Scott
